359 mower deck for Cub Cadet 782
HenryO
Any one know where to get parts for a 359 deck? I need the center pulley/spindle assembly for mine, Appreciate any and all help. Live in NE Ohio.
(quoted from post at 18:56:01 05/13/19) Any one know where to get parts for a 359 deck? I need the center pulley/spindle assembly for mine, Appreciate any and all help. Live in NE Ohio.
You could try onlycubcadets.com. They have sections for the attachments.
Those are for the 50C and 44C decks. I assume you want the cheapest solution used. Try Paul in Taneytown MD - 410-259-8031. Has over 200 cub cadets, from restored to parts tractors.
HenryO:
The Center Pulley Assembly for the 190-359-100 (50C) mower deck is: [b:23dc648850]959-3367[/b:23dc648850]
It can be had at your local Cub Cadet Dealer or numerous Internet Sources.
Not sure what a "359 deck" is, but a 50C or 44C deck used on a CC 782 uses what's called a water pump bearing, bearing itself is sealed and not rebuildable. Bearing number ST-745, The shaft and bearing assembly is replaceable, look up Cub Cadet Specialty and order on-line, access via IH Cub Cadet dot com. $68 for the ST-745 bearing plus some freight. Make sure your top and bottom housings tightly hold the bearing or you will need new top & bottom halves of the housing. I replaced everything on one spindle on my #50C deck on my 982 about 10 years ago, bill was $178.00 but the deck went from a poor cutting howling mess to a smooth cutting deck.
The older decks, CC 70/100/71/72 vintage decks with Timken tapered roller bearings are cheaper to repair but it's all relative. I had a well used and abused CC 129 with a 44A deck for 15 years, mowed a LOT with that tractor, never had a problem with any of the spindles. The other two spindles on my 50C deck are fine, but I use the new CC LX54 TANK zero-turn to mow now.
y parts Parts manual direct from Cub Cadet Corp say "Garden tractor attachment
50" mower
Model No.
359
On the mmower itself it say 359 50C. Thanks for your help. I am looking to get by for less than $200.
HenryO:
50C or 44C deck used on a CC 782 uses what's called a water pump bearing, bearing itself is sealed and not rebuildable. Bearing number [b:3ab367310c]ST-745[/b:3ab367310c], The shaft and bearing assembly is replaceable,
I also have a 50C deck and just replaced the Bearing (ST-745)[on the outer ones]. I also got it from CC Specialties in Minnesota.
