Charles D. zook
New User
Hello, Have a 415 J.D. with 54 in. shaft drive deck and was mowing and never had a problem, but the deck shut off, no noises, just like shutting off deck with the dash switch, as I was about done mowing. The dash lite shows mower as engaged, but pto shaft to mower is not active. Can any one tell me or have a diagram of the fuse panel circuit board? On the board there is a red light and a green light glowing and have no idea what this indicates? Would appreciate any info. available on explaining the fuse panel circuit board. Also could the problem be the pto relay on the board, or possibly the selenoid on back side of rear end, which apparently activates the internal clutch for the pto? Do not hear the selenoid activating when engaging pto switch on the dash. Seemed unusual that it would be a electrical problem occurring suddenly after approx. 2 hours of mowing? Any help would be appreciated.
Thank You,
C.D. Zook
Thank You,
C.D. Zook
