2002sliverado
Last summer I purchased a 2182 (Cyclops?) Cub Cadet tractor. I fired it up this spring and used it to pull a yard drag. I have never had a Cub Cadet beforehand. I had a 318 Deere, which I traded for my 425 AWS about 7 years ago. Really like the 425 and it is what I use for most of my mowing. I had always wanted a Cub Cadet and got into this one quite reasonable. I will be changing out all the fluids and filters, changing spark plugs, etc. Last fall I noticed something which concerned me a bit. I tried out the mower deck and it needs belts and blades in the worst way. My concern stems from an observation I had while using it and turning. When I turned one direction, it was quite obvious the tractor would slow down. While turning the other way, it seemed like it may have speeded up................all with respect to ground speed, rather than engine speed. Any thoughts out there? I cannot believe this is normal, but I thought I would ask. Again, I would appreciate some thoughts on the matter. Thank you.
