ironandsteel
I have a kubota T1760 garden tractor/mower that is susceptible to getting water in the fuel tank if I leave it out
in the rain. Whether it is leaking in somehow through the cap, or it is from condensation, I don't know. You can't
get a siphon hose to reach the bottom of this tank (which is thick white plastic) because of the offset filler
opening, so I can't get all the water out of there.
I'm really tempted to install some sort of tank drain at the lowest point of the tank so I can get any water out of
there. It seems like I could drill and tap a hole and put in a screw with a neoprene washer. But I never see this on
mowers, so it must be really hard to make it seal.
I've seen blind bulkhead fittings for water tanks and am tempted to install one, but it is really larger than I
need.
need.
