Deere 212 steering gear adj?
Good morning!
I need info on adjusting my 212's steering gear box. I have about four inches of play at the rim of the steering wheel. Thanks for any info.
Dennis M. in W. Tenn.
Here's the adjustment instructions.
<img src = "https://i.imgur.com/Wx98Pgm.jpg">
Sometimes the plastic retainers in the ball bearings will fail, or the balls will get rough.
The tapered stud, "D", in the RH photo gets two flat spots worn on it by the "worm" over time, making adjustments without binding as the steering wheel is turn impossible.
Hi, Bob:
Thanks very much for posting the instructions! Can the procedure be done with steering column/box still in the tractor? Do other folks know of any short cuts to this job?
Should be able to do it on the tractor. There is also an adjustment on the bell crank that the tie rods attach too. Loosen the 5/16" bolt, remove the keeper on the bolt, tighten the bolt and reinstall the keeper.
The manual is confusing and does things in a roundabout way.
I would not unhook anything unless you need to replace tie rod ends.
I'd pump the case full of grease through the angled zerk on the top of the case.
I'd snug up the end plug like the manual says - tighten until it drags and then back out until you can get a cotter pin through.
Then I'd tighten up the big nut that holds the moving plate to the rest of the case.
Then I'd try adjusting the tapered pin. If it's badly worn, you won't get a good setting by turning it in - it will go from loose to stuck in a quarter turn.
That tapered pin is replaceable, and it makes a lot of things better in there.
Steve:
Thanks! that makes a lot of sense to me and I should be able to try those steps in next few days. I looked up the tapered pin's part number on internet Deere catalog, my local dealer seems to have one, price about $35.00. If my old part is really worn out, then It just depends how badly I want to get rid of steering wheel play. Thanks for the information!
Bell crank is on the 110/112 models, but thanks. I have one of those that's loose and hadn't figured out how to tighten.
Fixed!
I worked on it this morning, applied four squirts of grease, the adjusted the lug for least steering wheel play without causing binding anywhere in turning from extreme left to extreme right. Steering feel seems much better now. Thanks to folks' suggestions.
