All: Got a Onan P218 that will crank but no fire, at a loss and need help figuring this out. I have replaced the Trigger Ring, Ignition module, Coil, condenser, Plugs and wires. I do have fire now, but very very weak. I have jump the low oil pressure switch to by- pass or eliminate that for now. Battery is good....I suppose its possible I have bad new parts? The module shows battery voltage on part of the revolution then falls to 1-1.5 volts the rest of the revolution, just as the manual states it should. Connections are all cleaned, including battery ground to engine ground. Would appreciate any input you might have. Oh, when switch is on, there is battery voltage on + side of coil.
