Looking for a gas tank for a Cub Cadet 108
(quoted from post at 11:54:07 03/28/19) Do you not have one or does your talk have holes? If you have its, may be fixable. Used ones are expensive.
Don't have it. wasn't on the tractor when I bought it.
Gas tanks for Kohler engines in Cub Cadets have gotten STUPIDLY expensive. Used are almost as expensive
as new. CUB Cadet Connection has a couple used tanks, but nothing that fits a 108, for $95 to $130. Last
"New" tank I saw was $300 about 10 years ago. I put a new plastic Kohler replacement tank on my #72, was
$60 about 15 years ago and required lots of work and special stuff to make it fit under the hood. The
filler neck was over an inch tall and the included gas cap had a big dome on it.
I've made steel tanks for several Kohler engines. Nice thing with them is I make them larger than stock.
2 to 3 gallon capacity.
please send an email to hd 99 fxr 3 at yahoo dot com.
remove the spaces, replace at with @, and dot with .
thanks
