Round fender variator belt question
Could some one give me the part numbers for the drive belts for a 1966 J D round fender 110 please, thanks in advance. Larry
Go to the DEERE site linked below and enter your model #, then select the correct serial number range, and you can look them up for yourself and get the part numbers.
If you sign up with a dealer, you can go further and check pricing and availability.
DEERE parts
Glad to see you asking this question. Many years ago on my folks machine you find that those belts are half sizes. You will never get regular belts to adjust. BTDT
I found that out a few years ago my self. I tried cheap belts and they want work. FYI the part numbers are as follow. Primary belt part number is M82258 and secondary belt is number M44121.
I have this one torn down to the frame, almost ready to start back together.
These really are tough little machines. The cub cadets, bolens, simplicity, wheel horse, and others that had real BRASS to be called a "tractor" . Years ago one of the manufacturers ran a team of mowers across the country. Have no idea how much support they had or how much of the original machines were left. Then you run into these. Just too dang funny.
Cops and mowers
He is only going out for lunch. Actually after i watched a couple they must be training films dang funny though. There must be ten of them on Utube.
Lunch brake
