Gene Davis (Ga.)
I want to change my pull start 10 hp Tecumseh powered pressure to electric start. I can no longer muster the oomph needed to crank it since I will be 80 in a few months. I need the starter, flywheel with ring gear and the charging coil setup. It can be a low output charging system because it will crank once and run for a good while when used. The last one I converted I used the setup from an 8 Hp vertical shaft engine, so it can be from an 8 or 10 hp horizontal or vertical shaft engine. This engine is from the 1990's time frame. Any body got one they are willing to part with? E-mail me at: [email protected] remove the xs before sending.
