Company Logo Shop Now
TractorLinks.com
Trouble shooting the generator/voltage regulator
young tractor
03-06-2019 15:48:22
Hi guys. I apologize for all the questions on my cub Cadet 100. The tractor sat for at least 5 years without a battery in it. The generator/starter was supposedly rebuilt right before the steering went out. It doesnít seem to be charging. How do I go about trouble shooting the charging system? Do I need to polarize the generator and voltage regulator? Do you know what the air gap is supposed to be in the two points on the regulator. I really appreciate your advice.
Richard Holland
03-07-2019 18:19:19
 Re: Trouble shooting the generator/voltage regulator in reply to young tractor, 03-06-2019 15:48:22
Use a volt-ohm meter on the battery when it running and not. Volts should increase by about 2 when running. If not it isn't charging. There already is a post on polarizing it.
R Bedell
03-07-2019 02:56:42
young tractor:
Simple test. Ground the "F" terminal on the S/G briefly, and watch your Amp Gauge. If the Amp gauge goes to Full Charge, then you have a V/R problem. If it does not, then you have a S/G problem.
6jack
03-06-2019 16:23:51
https://simpletractors.com/articles.html/articles/electrical-systems/troubleshooting-the-briggs-starter-generator-system-r14/
young tractor
03-06-2019 17:51:05
 Re: Trouble shooting the generator/voltage regulator in reply to 6jack, 03-06-2019 16:23:51
Thank you for the link. I canít seem to click on it
t.r.k.
03-06-2019 17:13:33
Just want to add that we know your CC 100 has a Kohler in it, but the only difference between that and Briggs is the shaft in the generator itself turns backwards because it drives from the other end of the engine. Troubleshooting should be the same.
young tractor
03-06-2019 18:04:28
 Re: Trouble shooting the generator/voltage regulator in reply to t.r.k., 03-06-2019 17:13:33
I cut and pasted the link. I got it. Thanks
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
