battery draining update
Well being only 20 years old I should look over everything before I assume something went out to the shop and seen a wire hanging off the voltage regulator it is the B+ wire it must've popped off the positive battery wire. So I think I solved my problem!
You first asked about the battery draining between uses so it wouldn't start, but in reality, it was dying while running 'cause it wasn't charging!
QUITE a difference!
