Company Logo Shop Now
TractorLinks.com
flame out the exhaust
Dakota Wilson
02-11-2019 14:06:04
I hate to bother everyone with my wheel horse raider 12 but now I have another issue at least I think it is.Noticed when I'm running it at high throttle there is a little flame coming out the exhaust then when I throttle it down it backfires and there's a little bigger flame nothing to big though. what can I do to fix this issue?
steve_in_mo
02-11-2019 20:04:56
 Re: flame out the exhaust in reply to Dakota Wilson, 02-11-2019 14:06:04
The Kohler engine manual is available for free download from Kohler.
or from here: http://www.wfmfiles.com/download/Kohler_Owner's_Manual_Single_Cylinder_K241_K301_K321_K341.pdf
Spark plug gap:
Check gap using a wire feeler gauge. Spark plug gaps are as follows:
Battery/Breakerless . . . . . . . . . .035
Magneto . . . . . . . . . . . . . . . . 025
Initial carburetor settings:
Kohler Adjustable Jet K301
Low idle 2-I/2 turns
High idle 2 turns
There should be a puff of black smoke on acceleration if the carburetor is set correctly and the engine is warmed up.
Unburned fuel helps cool the engine.
Check for slop in the throttle shaft - it should not wiggle side-to-side in the carb body.
Initial points setting is .020 with the points fully open. You don't need a timing light unless you want to get fancy.
Bob
02-11-2019 18:25:58
Probably normal, up to a point.
If you are concerned, the first thing you need to do is read up in the service manual on setting the spark timing, then grab a timing light and check it out, adjust as needed.
Rogeriniowa
02-11-2019 17:36:53
What color is the flame? Red/yellow can be rich. Blue/white normal to lean.
Indiana Ken
02-11-2019 17:33:17
Late timing can contribute to burning after the exhaust valve opens. You say "flame out the exhaust" are you running the engine with a full exhaust and muffler system or just a short pipe in the exhaust port? If you are running a short pipe then the flame and back fire can be normal. The back fire can be caused by air mixing with the exhaust gas at the open end of a short pipe or with a full exhaust system with an air leak.
Jeffcat
02-11-2019 16:41:09
Just throwing this in. First the carb might be adjusted a little rich. See what the others say.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
