Re: JD ‘72 110 Battery Question
Bob
02-07-2019 13:04:18
If yours has standard automotive battery cable ends, looks like a 500 cranking Amps BCI 22F series battery is what DEERE shows in the Parts Catalog.
Third Party Image
Parts book also shows a bolt/tab terminal option. Post back if yours has that style of connections.
anvilheadtexas
02-07-2019 13:42:00
 Re: JD ‘72 110 Battery Question in reply to Bob, 02-07-2019 13:04:18
Bolt/Tab, but I am going to go with a 350 or so cranking amp battery . You’re suggesting 500 and there’s just no way that would make sense ? Unless I’m not reading something correctly???
Bob
02-07-2019 14:06:14
 Re: JD ‘72 110 Battery Question in reply to anvilheadtexas, 02-07-2019 13:42:00
A 1972 DEERE 110 could have 2 engines, a 10HP Kohler, which used an "automotive-style" battery, for which I posted the official factory "specs", NOT my "suggestion". (I didn't catch the "8 HP" detail on first read.)
You did not mention in your first post that yours had a "garden tractor battery" with "L-shaped posts" as the 8 HP Kohler engine version apparently left the factory with. The part number shown for your version is NLA from John Deere, so the "specs" no longer come up for that version.
The single-cylinder Kohler engines (even with ACR) take a bit of juice to get past compression and crank well, so get a "garden tractor-style battery" with the highest cranking Amps that's readily available to you.
As a point of reference, I have a garden tractor with a 12 HP Kohler and the largest "garden tractor-style" battery stocked locally when I needed one last year was a 420 cranking Amp, and it's none to big for the 12 HP.
anvilheadtexas
02-07-2019 14:12:43
 Re: JD ‘72 110 Battery Question in reply to Bob, 02-07-2019 14:06:14
Thank you Bob. For clarification gives me the reassurance as to what I am looking for ! I want to see the thing crank up and blow smoke!!! I am already for sure that it needs new rings I just have to see it for myself !
Bob
02-07-2019 17:20:02
 Re: JD ‘72 110 Battery Question in reply to anvilheadtexas, 02-07-2019 14:12:43
Anvil, if you don't already have it, you can download an official service manual for your engine for FREE (in.pdf format) at the link below.
anvilheadtexas
02-08-2019 09:13:23
 Re: JD ‘72 110 Battery Question in reply to Bob, 02-07-2019 17:20:02
I don’t!!! Thank you. This is going to be really useful as I suspect I will be venturing into the engine block to redo the rings . Bob, any suggestions in regards to redoing the rings .... are there other things I should definitely take care of while I have the engine open . Based on my limited understanding it appears to just be a bad rings.
