Company Logo Shop Now
TractorLinks.com
JD Ď72 110 Battery Question
anvilheadtexas
02-07-2019 12:48:27
I inherited my dadís Ď72 JD 110 (Kohler 181 8 HP) and I am having a hard time figuring out what battery I should put in it ? The manual says 12 V 24 amps. Iíve gone to Napa and they were unable to match it, AutoZone started talking about the number of cranking amps and thereís a wide range, Advanced just looked at me like I was high.
Can anyone out there tell me the number of cranking amps I need for this tractor and any recommendations on the best battery . Iím dying to see if this thing starts.
nevertomany
02-10-2019 18:43:18
 Re: JD Ď72 110 Battery Question in reply to anvilheadtexas, 02-07-2019 12:48:27
I posted a reply to your other post from Dec. But in case you haven't/didn't see it. In case you don't already have it the service manual for your entire mower is a Deere SM2101 that can be found here:
http://www.wfmfiles.com/download/manuals/SM2101%20(Jan-74).pdf
Hope this could help. Have a good day.
anvilheadtexas
02-07-2019 17:20:34
350 cca and this bad boy turns over and fires. I used starter fluid (no gas in tank). Smoked like crazy but I did add oil to the sparkle hole. Going to roll it outside Friday and put a shot of gas in her and see what happens!
Jeffcat
02-07-2019 13:13:48
What I have found. Go to tractor supply and look at the garden tractor batteries. I bought the biggest CCA one that is made for my Husqvarna garden tractor. The same battery will also start my CUB Tractor. Their web site is showing a 340 but I think mine is a 350 or something. Not that much more in price. Will spin anything over and it still fits.
anvilheadtexas
02-07-2019 13:40:02
 Re: JD Ď72 110 Battery Question in reply to Jeffcat, 02-07-2019 13:13:48
This seems to make sense? I just did not want to get something over-kill, but common sense says the battery can only be so big (10x6) is about the max.
Bob
02-07-2019 13:04:18
If yours has standard automotive battery cable ends, looks like a 500 cranking Amps BCI 22F series battery is what DEERE shows in the Parts Catalog.
Parts book also shows a bolt/tab terminal option. Post back if yours has that style of connections.
anvilheadtexas
02-07-2019 13:42:00
 Re: JD Ď72 110 Battery Question in reply to Bob, 02-07-2019 13:04:18
Bolt/Tab, but I am going to go with a 350 or so cranking amp battery . Youíre suggesting 500 and thereís just no way that would make sense ? Unless Iím not reading something correctly???
Bob
02-07-2019 14:06:14
 Re: JD Ď72 110 Battery Question in reply to anvilheadtexas, 02-07-2019 13:42:00
A 1972 DEERE 110 could have 2 engines, a 10HP Kohler, which used an "automotive-style" battery, for which I posted the official factory "specs", NOT my "suggestion". (I didn't catch the "8 HP" detail on first read.)
You did not mention in your first post that yours had a "garden tractor battery" with "L-shaped posts" as the 8 HP Kohler engine version apparently left the factory with. The part number shown for your version is NLA from John Deere, so the "specs" no longer come up for that version.
The single-cylinder Kohler engines (even with ACR) take a bit of juice to get past compression and crank well, so get a "garden tractor-style battery" with the highest cranking Amps that's readily available to you.
As a point of reference, I have a garden tractor with a 12 HP Kohler and the largest "garden tractor-style" battery stocked locally when I needed one last year was a 420 cranking Amp, and it's none to big for the 12 HP.
anvilheadtexas
02-07-2019 14:12:43
 Re: JD Ď72 110 Battery Question in reply to Bob, 02-07-2019 14:06:14
Thank you Bob. For clarification gives me the reassurance as to what I am looking for ! I want to see the thing crank up and blow smoke!!! I am already for sure that it needs new rings I just have to see it for myself !
Bob
02-07-2019 17:20:02
 Re: JD Ď72 110 Battery Question in reply to anvilheadtexas, 02-07-2019 14:12:43
Anvil, if you don't already have it, you can download an official service manual for your engine for FREE (in.pdf format) at the link below.
anvilheadtexas
02-08-2019 09:13:23
 Re: JD Ď72 110 Battery Question in reply to Bob, 02-07-2019 17:20:02
I donít!!! Thank you. This is going to be really useful as I suspect I will be venturing into the engine block to redo the rings . Bob, any suggestions in regards to redoing the rings .... are there other things I should definitely take care of while I have the engine open . Based on my limited understanding it appears to just be a bad rings.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
