Company Logo Shop Now
TractorLinks.com
briggs intek compression
gfj
02-06-2019 14:11:23
Can someone give me the correct compression for a briggs 6 hp intek engine? Thanks.
kencombs
02-06-2019 22:16:23
 Re: briggs intek compression in reply to gfj, 02-06-2019 14:11:23
first step is to adjust the valve clearance. That is critical to both starting and compression.
gfj
02-06-2019 19:45:00
It is a 1998 model and is on a dr trimmer. It runs fine once you get it started but seems short on power. One cylinder 6 hp.
gfj
02-06-2019 18:21:21
I am only able to get 30 lbs and engine is an electric start and hard to get started.
rustred
02-06-2019 19:04:46
 Re: briggs intek compression in reply to gfj, 02-06-2019 18:21:21
there is no hope at all that its gonna run on 30 lbs. need at least 80-90-lbs. better check compression release if it has one if not check the valve adjustment also, could have a tight valve. plus you didn't give any info on age of engine. can also be a burnt valve and it will definitely not run if its a one cyl,??? no info on that either.
t.r.k.
02-06-2019 18:14:48
Most Intek engines have a compression release mechamism on their camshaft, so I don't think there is any published number for compression on that engine.
That said, I've measured in the ballpark of 60 psi. on more than one new engine.
If you are wondering about the valves, a leakdown test may be in order. If you don't have a leakdown tester, you can feed a regulated an air supply into the sparkplug hole with an adpater at 10 to 15 psi and listen at the muffler, intake, dipstick to find where its leaking at.
