Company Logo Shop Now
TractorLinks.com
simplicity vs john deere
steve19438
02-04-2019 08:45:50
a short time ago I had a fella tell me a simplicity garden tractor will do a better job of mowing than a JD. size of machines was not mentioned nor was zero turn units.
what gives ?
Bret4207
02-09-2019 07:06:54
 Re: simplicity vs john deere in reply to steve19438, 02-04-2019 08:45:50
It depends on the Cub cadet and the Simplicity. Cub Cadet made some real cheap tractors, I own one. They also made some real good ones. Simplicity made the same, good and cheap. The older Cub Cadets and older Simplicitys were a different animal than what we get today unless you pend thousands and thousands.
Dieseltech
02-05-2019 18:52:38
Far as zero turn mowers go, I have a Skag diesel now that mows MUCH better than the Simplicity zero turn I traded in..
504
02-05-2019 18:32:27
I agree JD does not mow very well. I have a 430,455,F932 & a 332 all JD. I have had a 12,14 ,16,18,20, and a 25hp Simplicity. The jd were cheap but the orange ones were better mowers
Married2Allis
02-05-2019 06:22:01
t.r.k.
02-04-2019 18:37:24
Just want to add:
That roller in the back of the Simplicity deck is also a dandy thing to grade your driveway with. Just drive one across a patch of loose gravel and you'll know what I mean.
Lance Skene
02-04-2019 16:59:29
Simplicity have always been known for leaving a nice finished cut, the decks follow the ground well and they are deep with good airflow.... a good design that works well.
Simplicity also builds Allis Chalmers, Deutz Allis and AGCO Allis.
Jeffcat
02-05-2019 08:15:41
 Re: simplicity vs john deere in reply to Lance Skene, 02-04-2019 16:59:29
My Husqvarna does a very nice job too. The deck is taller and also has air flow baffles underneath. Machine is built by AYP products. They offer a fabricated deck that is even heavier and works even better. You want a machine, look at the latest simplicity model. Start price is only $4000.oo.
gab
02-04-2019 10:25:49
Probably because some or maybe?? all their decks have the roller across the back that makes the lawn look as smooth as a table top.
kencombs
02-04-2019 09:34:46
Most Simplicity decks don't hang from the tractor but instead are pulled my the tractor and ride on the ground. The JD, (and most others) hanging from the deck will 'dip' and scalp when a wheel hits a low spot. The Simp will follow the ground under the deck. Small difference, but if one wants a carpet cut, the ground following deck will provide it.
case and Ingersoll are also ground supported, and that's why I have some.
steve19438
02-04-2019 09:49:19
 Re: simplicity vs john deere in reply to kencombs, 02-04-2019 09:34:46
thanks.
steve_in_mo
02-04-2019 09:09:02
Did he have a Simplicity machine for sale, perhaps?
t.r.k.
02-04-2019 08:55:55
I guess you need to ask that fella what he meant.
oldsarge
02-04-2019 20:23:27
 Re: simplicity vs john deere in reply to t.r.k., 02-04-2019 08:55:55
We all know that anything is better than a Cadet anyway!!!!!!!!!!!!!!!!!!!!!
DR. EVIL
02-09-2019 05:45:24
 Re: simplicity vs john deere in reply to oldsarge, 02-04-2019 20:23:27
you have NEVER been around one to make a stupid comment like that. I have a 1965, 1968, 1980, and 2014 zero turn Cub Cadets. I had 3 coworkers all buy new Simplicity lawn tractors years ago. None lasted over 4 years. I ran my '68 more hours in one year than ALL 3 Simplicities ran combined in four years.
