Company Logo Shop Now
TractorLinks.com
Attaching an alternator to a tractor to power an inverter
Greenfrog
01-31-2019 17:17:34
I have pto pulley on my CC108 and 129. I want to attach an automotive alternator via a belt to generate AC volts to run an inverter....
Question: what type, size, etc. might work best? How to mount?attach? ... I would rig up something Any suggestions? Wiring.? Will it work?
Married2Allis
02-01-2019 07:19:31
 Re: Attaching an alternator to a tractor to power an inverte in reply to Greenfrog, 01-31-2019 17:17:34
Belt-driven Pincor generators were once available to install on Cub Cadets using the front end PTO mount. A QA42 snowblower mount may be a good start to building a platform for a belt-driven generator like this one available from NT. Your IH 129 would handle 5000 watts - requires 11hp and 3600 rpm. It's safe for electronics, has +/- 5% THD rating. Probably more practical than rigging up a large inverter.
Texasmark1
02-01-2019 07:02:18
 Re: Attaching an alternator to a tractor to power an inverter in reply to Greenfrog, 01-31-2019 17:17:34
Watts in (VxA, PF=1 if talking about AC circuits) equals watts out minus losses....746 watts per 1 HP. Keep in mind that to work for you, if you are using an RPM rated unit, you may be running a 400 cu inch engine at redline RPMS to get the RPM ratio to run your 400 watt generator/alternator at 400 watts. Neighbor's boy had one years ago, don't remember anything about the unit but I installed it in his truck, of similar sized engine, at his request, and what I said above is what happened. Efficiency??????? Totally sucked! Turned me off them right away.
Course technology and all today, surely things are better now.
greentoad
02-01-2019 06:24:53
I'm gonna build one of these suckers. Already have an inverter that is 2000W/4000PEAK. Do I have to put a battery in-between the alternator and the inverter is the VR on the alternator good enough to regulate input voltage?
Jeffcat
02-03-2019 19:58:10
 Re: Attaching an alternator to a tractor to power an inverter in reply to greentoad, 02-01-2019 06:24:53
You absolutely need a battery to act as a buffer. The whole system will be totally unstable and most likely one or both will fry very quickly. Maximum smoke.
Bob
01-31-2019 18:15:24
"I want to attach an automotive alternator via a belt to generate AC volts to run an inverter...."
Your post is a bit confusing, by definition, inverters convert DC current to AC current, so you don't want AC Volts to run an inverter, IMHO.
I'm gonna GUESS you want a 120 Volt AC power source?
If that's what you want, I think CC dealers sold PTO driven AC generators, for sure DEERE did.
Here's a link to a thread posted by someone who fabricated one.
Jeffcat
01-31-2019 17:54:01
Lots of how to videos on Utube. You need a very small altinator like Hitachi makes, a darn fast engine or engine pulley to altinator ratio speed, a very large storage battery, and a honking big inverter. Will never work like a portable generator from Lowes. Made a super duper portable battery charger many years ago with a ten horse motor if memory serves and no inverter just straight big storage battery. It really worked but not very practical. Just take a garden tractor and jumper cables.
