J. D. Unstyled
Gasoline contaminating the engine oil. I suspect the problem is with the electric fuel shut off solenoid at the bottom of the carburetor though I am not sure. A new solenoid from John Deere is ridiculous... Over $300 Canadian, too much to try it and see if it helps.
Electrical continuity is good on the old one and power seems to be getting to it. (I guess I should check the continuity to ground in the harness. Oops.) If anyone has had this problem I could use some advice. Thanks in advance
