Company Logo Shop Now
TractorLinks.com
case 444 trans fluid
Dakota Wilson
12-30-2018 11:41:06
So I plan on changing my fluids in my case 444 I don't have a book for it for the trans oil the only plugs i see is the drain plug and the fill plug on the rear of the tractor I was researching online and seen that there is a check plug on case 444 by the drain plug i don't see that on mine? Do some case models not have check plugs my Serial number is 9739635 thanks for the information!
Dakota Wilson
12-30-2018 11:44:58
 Re: case 444 trans fluid in reply to Dakota Wilson, 12-30-2018 11:41:06
Sorry the serial number is actually 9739365
tom arnold
12-30-2018 12:27:09
 Re: case 444 trans fluid in reply to Dakota Wilson, 12-30-2018 11:44:58
The earlier models came with a drain plug and a fill plug in the trans-axle. Later models included a "level plug" because they changed the amount of oil Case put in the trans-axles. No one has uncovered the reason why this was done. On your tractor, you should operate the tractor until all the fluids are nice and warm and then unscrew the drain plug in the trans-axle and leave it drain until all you get is the occasional drip. Then put the drain plug back in and pour new oil slowly into the fill plug hole until it begins to flow back out. When it stops flowing, install the fill plug. You are done. As for oil, you have several choices. You can use common hypoid oil that is used in cars and trucks, although there is no real reason to do so.. OR...you can use 20W50 or 15W40 motor oil or 30 weight motor oil. All will work equally well.
As for the hydraulic system, 15W40 is the popular choice for year around service. In very hot climates, 20W50 is a better choice. In cold weather 10W30 will help in engine starting.
masseyharrisguy
01-05-2019 15:49:06
 Re: case 444 trans fluid in reply to tom arnold, 12-30-2018 12:27:09
Tom, would it be satisfactory to use 15w-40 diesel oil in the hydraulic drive?
Thanks
Frank
tom arnold
01-05-2019 16:19:25
 Re: case 444 trans fluid in reply to masseyharrisguy, 01-05-2019 15:49:06
YES...... 15W40 is a good choice. Do not worry about whether it is spec'd for diesels or not. It is the grade that counts the most.
