DMartin9N-2N
Hi to anyone who knows Variators:
My 212 Deere has gotten slow to start moving when I release the clutch pedal if variator handle is in first notch. When I go to second notch, it seems jerky and sometimes I hear a belt chirp. I am quite sure it has been hundreds of running hours since the variator received its graphite treatment. Does it seem likely I need to do the graphite thing again? Also, if it is needed, what is the most practical way to gain access? I can use a hydraulic floor jack, ramps, overhead hoist, whichever will make the actual graphite job easy. Also wondering if fender pan needs to come off. I do have a pretty good 2 car garage with concrete floor, so having a good work area is no problem. Thanks for any knowledgeable advice!!
Dennis M. in W. Tenn.
