Hello,
I need some help finding a few parts for my Gilson. I need a drive belt, Tension pulley and the bolt holding it on. Sleeve that spaced pulley was damaged and is causing pulley to bind and burnt up belt. Attached is the model number plate and pics of parts I need. If you are on your back I need the tension pulley that is on the right of the tension assembly. Thanks for your help in advance.
Ryan
[/img]
Ryan
