craftsman yt3000
MI-Bill
I mow a small area that requires frequent reverse and forward movement. the safety feature that does not allow the mower to work in reverse is a real nuisance. I would like to disable it. I have owned a earlier model that was basically the same but did not have this feature. So, how do i go about disabling it? A wiring shunt? OR?
I was thinking that all those YT3000 tractors had the Mow-in-Reverse position on the ignition switch. But I know that designation was used on several different models of tractor.
Should be a switch on the gear shift that senses the reverse position, just disconnect it. Or if it has a bypass switch put on a jumper wire so it is always on.
