Company Logo Shop Now
TractorLinks.com
Restoring Cub Cadet 1450 Light Asssemblies
RTR
11-28-2018 15:02:53
Is anyone familiar with these taillight assemblies on a Cub Cadet (1970s IH built ) 1450? Mine are missing the bulbs, lenses, and who knows what else. Just trying to fix this one up on a budget ajsnwanting to keep original if possible.
For the front light....it is being held in with scrap electrical wire. What holds it in the screen wire? Just the rubber gasket? How to fix?
Needing help to know if the assemblies are broken and if any partsbare kissing other than bulbs and lenses. Also need to know where to find used parts.
third party image
third party image
third party image
third party image
third party image
R Bedell
11-30-2018 03:11:02
 Re: Restoring Cub Cadet 1450 Light Asssemblies in reply to RTR, 11-28-2018 15:02:53
RTR:
The 1450 was part of IH/Cub Cadet's "Quietline" series. Within that series, the following models had rear reflectors and no lighting.
* 800
* 1000
* 1200
* 1250
The following models had lighting as standard equipment:
* 1450
* 1650
RTR
11-29-2018 14:32:24
Thanks for the tip. Actually this model 1450 original came with tail lights from the factory so the wires are already there!
RTR
11-29-2018 12:10:34
Wanted to share what I found today. I found some universal marker lights that should resemble the OEM lights close enough and should work well. Hoping the bolt pattern lines up but if not it isn't a big deal to bondo a hole and drill another. Have a look at these.....they look close to a factory look without looking too gaudy or "not original looking" like the rounded ones.
third party image
third party image
third party image
third party image
jeffcat
11-29-2018 13:03:38
 Re: Restoring Cub Cadet 1450 Light Asssemblies in reply to RTR, 11-29-2018 12:10:34
Now you did some good hunting on those. Here is what you need to remember. Originally those rear markers were just safety reflectors. No light bulbs in them. My Big Husqvarna was set up with just reflectors like that. She now has a set of LED markers "tail lites"that look just perfect. Just be careful of your wireing so as not to pinch anything. If you have wires hanging here is a super duper trick. A glass cutting shop should have this. Get hold of some of that white double sided sticky mounting tape. Comes in rolls like two or three inches wide and maybe twenty or thirty feet. They should have a partial roll to sell you. That stuff is incredibly sticky!! "The commercial stuff". Clean the surface underneath with a little thinner. Position the wires. Then cut a inch or so wide bandaid size piece of that tape. Hold the wire and stick on the tape. It will not fall off in your life time. Works fantastic. There are also plastic clip things with that tape on them but they just don't stand up. The only easy way to remove that tape is with paint thinner. Hope I helped!
third party image
RTR
11-29-2018 06:34:45
Thank you for that info!!
R Bedell
11-29-2018 04:09:48
RTR:
The headlights are held in by #IH-107333-C2 Mounting Ring. You can still find these on the internet.
The Tail Light Assembly (IH-545616-R1) is NLA from Cub Cadet. However, the 1895 Lamp is available in any Auto Parts Store.
The lens (IH-55187-C1) is available from: https://www.ccspecialties.org/electrical.html
As stated prior, IF you are not concerned about being OEM correct, many Truck "clearance lights" will fit in there.
RTR
11-28-2018 20:01:06
Thank you all. I'll just look for new marker lights I guess. Much cheaper than OEM lights. I'll check out the rubber ring and make sure it doesn't need replacement.
Jo Bird
11-28-2018 19:39:29
" What holds it in the screen wire? Just the rubber gasket? How to fix? "
Yes the rubber ring holds the light in the screen. Cut the wire holding the light on the left, remove the rubber from the light. You should see a ring cut around the rubber , pull the front of the rubber through the wire screen as the light on the right and then push the light in the rubber from behind. Note most of these have a reference notch in the rubber that matches with a boss on the light , this keeps the light / lens in the proper orientation and from spinning in the rubber. A little lubricant on the rubber will aid in installing the light into the rubber.
Bob
11-28-2018 17:27:43
As to the tailights, they are just basic red truck clearance lites.
If they have to be 100% original I can't help you, but if "close" is good enough, stop at an auto parts store that has a tailite dispay and have a look.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
