Company Logo Shop Now
TractorLinks.com
Re: Intek oil seal problem resolved...
johnlobb
11-11-2018 05:29:48
Yes, these 3 engines are all 2 cyl Intek B & S. 2 are 20 hp, the oldest one (2001) is a 22 hp. Watching those YouTube videos, I know the gasket you're talking about. It's probably Ethanol laced fuel that causes the swelling. The one that is a problem is one I bought used and it shows a lot of signs of abuse. It's a 20 hp 2002.
jeffcat
11-12-2018 18:13:56
 Re: Intek oil seal problem resolved... in reply to johnlobb, 11-11-2018 05:29:48
OK...did you try that little test? Another thing with these engines. The upper and lower crank case is held together with 9 ?? Bolts. Make sure all of them tight. They loosen and start to leak out of that paper thin gasket. Briggs found a simple fix......put some loctite on the stupid bolts! I prefer nail polish. Costs only a buck a bottle and the stuff holds really well. Another thing...try either NGK BPR6ES plugs or the NGK iridium plugs. They are BKR6EIX-11. Cost around $8.oo each local but go on Ebay You can find a box of four at around $16.oo. They are increadibly worth the cost. The engine will start before you can let go of the key. Don't forget a dab of copper never seize on the plug threads. Hope you change out that messed up carb. A new one will work so well I bet you will change out the other two machines. The first one I bought two years ago was 135 dollars and they now cost around 45 bucks. The parts kits cost more than that! Have fun!
third party image
third party image
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
