Company Logo Shop Now
TractorLinks.com
Jacobsen transaxel needed
wilson ind
10-19-2018 15:58:22
Need a transaxle for Moline garden tractor. Made by Peerless and used in Jacobsen Chief and others. Unit has belt drive on left side. Would be from a horizontal shaft engine. R]E mail is open.
AVERIE
10-22-2018 18:13:55
 Re: Jacobsen transaxel needed in reply to wilson ind, 10-19-2018 15:58:22
Where are you located?? Shipping also might be a problem for you . There also may be someone local that may have what you are looking for.
Lance Skene
10-21-2018 05:56:00
There was several differant peerless transaxles available, the 4 spd was the most common but according to tractordata the MM used a 3 spd
John in Mich
10-20-2018 15:49:54
A internet search should locate a tranaxle in a salvage yard. They are all over the country.
Lance Skene
10-19-2018 18:08:39
Might be tough to find an exact match but those same transaxles were used in alot of differant tractors, often the brake drum/rotor or drive pulley is differant, or the hubs/axles are diff... but the internals are the same so you can swap parts easily and they are an easy transaxle to work on.
Most common issue is the detent springs/balls on the shift forks get weak and the lever gets sloppy, then the tranny can jump out of gear or get stuck in between gears.
