Cub cadet 2135
cuby
I am in need of a fuel pump for this mower. It has the Kohler Command OHV 12.5 horizonal shaft single cylinder engine. Pump is on right hand side of engine. Good used would be ok.
Is that the mechanical pump in the valve cover or is is a diaphragm pump? If it is the mechanical pump, and you just want it to work, not be original, you can convert it over to a diaphragm pump. There are Youtube videos on how to do it.
Personally, I wouldn't take a chance on either of the pumps being 'good used'. There is a lot of risk in used parts like that.
How would a low pressure{ 2.5--5 psi} electric fuel pump work on that?? Have read where it has been done, but do not know the results.
