Ranch King GT
CKain(MI)
I have a RK with Brigg 20. Ignition problem.
I found a 'fried' area, involving wiring in ignition circuit.
a diode in-line. I cannot find a schematic that shows any diodes at all.
Can Anyone enlighten me as to are they necessary or where to get a service manual.
RKGT20H46A Thanks.
That diode is most likely part of the alternator system that the engine has for charging the battery. The alternators on engine like that are very simple and the ones I have messed with had a single diode to make it so as not to send AC current into the battery
That wire is the source of AC, generated by the charge coil, which is rectified by the diode to create DC to charge the battery.
Hi... You Seem to be Fluent in Small Engines...?.Can You Possibly tell me what Size The NUT is on My 23Ar6 Briggs Cast Iron Engine Crank ShaftIve got to Buy One, As, , I have No Spark and cleaned the Points, Must be the Coil, Bad or need Cleaning of the Magnets etc.:Id app it thanks Larry
