Company Logo Shop Now
TractorLinks.com
Ranch King GT
ckain(mi)
09-30-2018 15:01:47
I have a RK with Brigg 20. Ignition problem. I found a 'fried' area, involving wiring in ignition circuit. a diode in-line. I cannot find a schematic that shows any diodes at all. Can Anyone enlighten me as to are they necessary or where to get a service manual. RKGT20H46A Thanks.
ckain(mi)
10-10-2018 17:24:29
 Re: Ranch King GT in reply to ckain(mi), 09-30-2018 15:01:47
I Thank all that replied, the engine is now running quite well. just needs a gov. assy, now !! :(
t.r.k.
10-01-2018 09:09:00
if its 2 cylinder, there are also diodes in the kill wire under the engine cover.
motorcraftman
10-01-2018 14:47:18
 Re: Ranch King GT in reply to t.r.k., 10-01-2018 09:09:00
Hi... You Seem to be Fluent in Small Engines....Can You Possibly tell me what Size The NUT is on My 23Ar6 Briggs Cast Iron Engine Crank ShaftIve got to Buy One, As, , I have No Spark and cleaned the Points, Must be the Coil, Bad or need Cleaning of the Magnets etc.:Id app it thanks Larry
ckain(mi)
10-03-2018 18:59:36
 Re: Ranch King GT in reply to motorcraftman, 10-01-2018 14:47:18
Sorry, I do not know the size of the crankshaft nut...
Lance Skene
09-30-2018 19:12:43
You can DL any BS engine manual directly from their home site
ckain(mi)
09-30-2018 17:25:49
another question, what does 12v go to 'under' the flywheel. Briggs Twin 20hp.
ken combs
09-30-2018 21:35:32
 Re: Ranch King GT in reply to ckain(mi), 09-30-2018 17:25:49
That wire is the source of AC, generated by the charge coil, which is rectified by the diode to create DC to charge the battery.
ckain(mi)
10-01-2018 08:04:42
 Re: Ranch King GT in reply to ken combs, 09-30-2018 21:35:32
Thanks Ken
old
09-30-2018 15:49:51
That diode is most likely part of the alternator system that the engine has for charging the battery. The alternators on engine like that are very simple and the ones I have messed with had a single diode to make it so as not to send AC current into the battery
ckain(mi)
09-30-2018 16:48:19
 Re: Ranch King GT in reply to old, 09-30-2018 15:49:51
thanks OLD, that makes sense...
