Ignition coil
NOT without using an external resistor.
The dwell period is different on Kohler one-cylinders than the typical automotive engines and some of us believe a genuine Kohler coil gives better point life than subbing an automotive unit.
Others say that's total hogwash.
In either case, the coil you have WILL work, at least for a while, if you use an appropriate ballast resistor with it.
Ih10020:
The original and correct Cub Cadet/Kohler Ignition Coil has an internal resistor to their coils, thus NOTHING else was needed to fire the Kohler K241 Engine.
