Company Logo Shop Now
TractorLinks.com
Ignition coil
Ih10020
09-30-2018 12:26:54
Can a coil marked USE WITH EXTERNAL RESISTER be used on a cub cadet 100 with kohler engine? Thanks.
R Bedell
10-01-2018 04:01:32
 Re: Ignition coil in reply to Ih10020, 09-30-2018 12:26:54
Ih10020:
The original and correct Cub Cadet/Kohler Ignition Coil has an internal resistor to their coils, thus NOTHING else was needed to fire the Kohler K241 Engine.
third party image
Bob
09-30-2018 13:56:42
NOT without using an external resistor.
The dwell period is different on Kohler one-cylinders than the typical automotive engines and some of us believe a genuine Kohler coil gives better point life than subbing an automotive unit.
Others say that's total hogwash.
In either case, the coil you have WILL work, at least for a while, if you use an appropriate ballast resistor with it.
Sprint 6
09-30-2018 13:53:46
If you use an external resistor. The original coil was internally resisted.
