I have a 2007 vintage Toro Z Master 60" mower, had it about 4 years, bought it with 2000 hours. Replace the engine last year with a new Kawasaki, new PTO clutch, new belts, spindles, etc. Ran great, not an issue at all. Today, I was running it in some thicker stuff, something must have hooked the wires that go to the electric clutch and pulled the wires down and into the deck belt. The mower stopped. I found the wires, wrapped them up as best I could, sorted out what had happened and tried to start it up. Nothing. Looked around and found nothing out of the ordinary, but I also had no relay click or solenoid click. Check the fuses and someone replaced all three with 40 Amp maxi's. One was blown, replaced it and I got my click from the relays, but no start. No crank, no start, nothing. Tried jumping it from the battery, nothing. Jumped the solenoid terminals and she cranked. Turned on the key, jumped the solenoid, started right up. Pulled the PTO button, nothing. Not a thing. Soooooo.....I drove it back to the barn and looked around and established the following. 1) Battery is fully charged. 2) When it is running, it is charging. 3) Both relays that are switched by the handles, click when you move the handle bars. 4) Replaced the solenoid (because I had an extra laying around), no change. 5) PTO clutch, when by-passed, engages and disengages when touched to 12 volts, so it still works. 6) Pulling the PTO button does nothing.
Please help in any way.....
