Have a snapper rear engine rider with an electrical problem but I cannot find it. Sorry for long post. Starts and runs great, Briggs single cylinder, when you let up on pedal, it dies with mower engaged or not. Safety switch, it has three. One on seat, on on mower deck, and one under neath the rear but I'm not sure what for because it has the lock out bracket for reverse so you can't put in reverse with the deck engaged. All three seem to be open switch that contact when closed, or plunger pressed. I have used jumper on all of these and tested them all as either open or closed. It has the grounding block on the motor by the throttle bracket that the ground to kill wires hook to. I can unhook the kill wire to coil and it works fine, just won't die until grounded out. I checked all wiring and no bare spots on any of them.this mower has minimal wiring on it. Under the seat behind the battery on the right side by the solenoid, it has a plug with all the safety wires running to it with what looks like some sort of relay. Unsure what it is or does. Ignition switch is just basic off-run-start. Possibly bad ignition switch? Any ideas?
