Hi all!
‘91 MTD type 130-600-000 14.5 h.p. riding mower with no brakes! Transaxle is Peerless 719-3013. Replaced brake pads on transaxle brake caliper, installed spring in tightest spring hole on brake actuator rod, but still had slop, installed a shorter spring. Adjusted brake caliper lever to minimum clearance. Foot pedal does seem to be actuating brake caliper.
With back wheels all the way off ground, gear selector lever in Parking Brake position, and F-N-R lever in Forward, the wheels still freely turn opposite each other.
Brake disc is on a splined shaft, not the keyway type, and disc is good on splines. Tightening brake lever at caliper does pinch the brake disc as caliper pins press against brake pad backing plate. It seems like, in gear and moving, stepping on brake slows tractor some, and it may come to a stop, but may still roll. Downhill not good at all. Also stomping brake on loose gravel won’t lock up the rear, axles still turn some. Pulling a small trailer, brake doesn’t even slow it down, yee-haw gets interesting!
Thanks for any suggestions!
