My Mf10 will not start in cold winter conditions. I set up a heater blow towards the engine for aprox 20 min and it will start at first compression. Runs beautiful, has plenty of power, doesn't skip a beat. My suspicion is that it doesn't have spark when its cold. Either because it's cranking speed is somewhat slower with cold oil or maybe the magneto fails at a certain cold temp. Tractor has the original cast iron 10hp Tecumseh engine, new points and condensor. It has the belt driven starter/generator. I have tryed boosting it with my truck, when its cold it can crank all you want, no start. A little heat and it starts instantly. I removed the spark plug and checked spark. Spark ok but remember that with plug removed it cranks faster too. Any help or advice would be appreciated.
