Getting the deck away from the 4020! How?
4435
So I have the big Ingersoll. Now when I need to remove the deck what is a slick way to do so without bodily damage?
The 444 is light enough in the front I can grab it by the tie rod and lift it on the deck then push it back. Not so much the 4020.
Secrets please! Less the two post car hoist.
Thanks Tom
Jack up front end,put cinder blocks under wheels,repeat at rear.Slide deck out sideways.If blocks interfere,get a helper,use 5th block and lever(2x4?) under front axle to remove one"wheel block" temporarily.
