Bill Newhart
Need some sage advice on a John (near) Deere L110 start problem. Wife used it yesterday and put it in the barn last night. Would not start this AM. Spark is good, will fire initially with a wiff of starting fluid but quickly dies after wiff!! Repalced fuel filter, gas will run out of hose at carburetor but not fast. Gas will run at heavy flow with hose disconected at carb and starter turning. Choke works fine never had a problem before with this machine and has very low hours. This is a 17HP B&S engine with a "thingy" at the bottom of the carb bowl it has wires to it. Remindes me of some older carbs that had a main metering jet in the bowl base. Disconnecting the wires didn't affect anything. Then the "thingy" that allows crankcase vapors to be sucked into the intake has me suspicious since it does interrupt the fuel line. But I can't seem to find any fault with it. This sucker has me stumpted and I need to get it fixed so the wife can continue mowing the grass. Any ideas????
