Does anyone perchance know if the blocks for the gas and diesel majors were bored for the same sleeve O.D.? I.e., could you put diesel sleeves in a gas block without machining the block? I'm
kind of hoping the gas sleeves are the same O.D., just a little thicker wall.
Wacky idea, but here's why I ask: I have three gas majors. As many folks here know, some parts for the gassers are impossible to come by: Head gaskets, pistons/sleeves, and ignition parts for
the gassers are all pretty much non-existent. I have three gas majors, and one of their engines is getting really long in the tooth. Tranny, rear-end, hydraulics, front end are all tight, but
the engine is burning a lot of oil and down on compression.
I was originally going to relegate this to a parts tractor for the other two, but am not sure if I can bear to give up on it. If the diesel sleeves fit in a gas block, I was wondering about
putting diesel pistons/sleeves in her and having the hollow on the diesel pistons machined a little larger to give it a lower compression ratio - suitable for gas. I'd probably still bump it
up a little from the original 5.5:1 - probably go to something like 7:1 or 8:1. The crank and rods should handle it fine as they're the same as the diesel, and with modern fuel being higher
octane and a little playing with timing, I think the rest might be ok. My thinking is this would be kind of like the 'Fire-Crater' piston option International offered for the M's etc. - a
little more power through a little higher compression ratio. I doubt I'd get much more power with the original carb, but it might bump it up to 40 HP or so, and allow me to use standard diesel
sleeves, pistons (modified), and head gaskets.
Crazy idea? Feel free to criticize.
