Helping a friend with his fordson major diesel tractor. Tractor hasn't been run for years. Started but has a water leak into the base. I wanted to
know: Are these diesel engines wet sleeves? I suggested removing the pan and looking to see if a water leak could be seen around one of the
sleeves. He wants to make the tractor lawn art I think he should repair to running condition
Questions: how to determine where the water leak into the base is occurring He replaced the head gasket but water still leaking into the base.
Are these diesel engines in the fordson major diesel wet sleeves?
What is the sleeve remover size for removal of a sleeve in the fordson major diesel. Wanted to do the work in frame . I have an OTC sleeve puller
but do not have the remover plate for bottom of the sleeve.
Suggestions on how to determine where the water leak is occurring
