Company Logo (800) 853-2651 Shop Now
Fordson Tractors Discussion Forum
Super delta injector pump
Jhinschen
12-30-2022 17:29:13
Hi, I have a new performance super dexta with a simms minimec P4696 pump. My issue is that I have fuel being delivered from no.1 and 3 delivery valves but not no.2. I have removed the side plate and observed all three plungers working as they should, therefore my issue I believe is with the delivery valve itself or the delivery spring. I need to remove the delivery valve holder. However would someone know where I can get hold of the required socket in Australia as I m having trouble locating one. Thanks.
Jhinschen
01-06-2023 12:00:26
 Re: Super delta injector pump in reply to Jhinschen, 12-30-2022 17:29:13
That's it Dennis, talking to the old fellas who have worked on things for years out of necessity if usually your best option , provided you know what your doing. Anyhow back to my minimec, I replaced all three springs, new oil put it back together and she purrs like a kitten.
Jhinschen
01-01-2023 02:01:52
 Re: Super dexta injector pump in reply to Jhinschen, 12-30-2022 17:29:13
Hi majorman, thanks for your reply. I too am an old diesel mechanic cut my teeth on ford tractors and toft cane harvesters. I split the pump today and found the number 2 element spring is broken. Will contact a few fellas I know on Tuesday to find some new ones. Thanks again for your info.
Majorman
01-01-2023 01:43:46
Welcome to YT, as an old Ford and Fordson tractor mechanic may I offer you a bit of advice. Take your pump off and take it to a diesel repair shop, I will guaranty that you have neither the tools nor the conditions in which to work on it. I was trained in the diesel shop of a Ford dealer and the injection pump is the only thing on my tractor that I will not attempt to repair. If the pump is not correctly set after repair it can cost you a new engine or at least a very expensive pump. This is my opinion only and it is your tractor.
The problem could be a broken plunger spring or a jammed plunger. A delivery valve tool is available from e-bay, both new and second hand. If you do strip the pump out, be as clean as you can be, the clearances in the pump are very fine and even holding two parts in your hands when they are dismantled, can cause them not to fit back together. Any scratch marks on components can make the pump inoperable.
Where are you in Australia? I have a number of friends out there who may be able to help, This site will not allow me to mention the name of the Fordson Club or post its contact details.
Sorry to sound a bit negative but I have seen a number of people cost themselves lots of money by trying to repair their own injection equipment.
560Dennis
01-06-2023 11:49:22
 Re: Super delta injector pump in reply to Majorman, 01-01-2023 01:43:46
Very informative reply ,Id say cause you never want to incur more cost than is absolutely necessary to correctly resolve the issue the first time. Id ask your pump jobber for references , what experience that have with this pump. Im a novice when comes to pumps ,but I seek out the very best jobber I could find to repair my tractor pump. Quality cost less !
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
Latest Ad: Looking for a Farmall super h steering housing the big cast piece in front [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
