Company Logo (800) 853-2651 Shop Now
Fordson Tractors Discussion Forum
FMD Hydraulic Leak Down
LipRipper3006
11-19-2022 10:18:10
Just went through the hydraulic system on a Major Diesel. I re o-ringed the pump, valve body, and cylinder with a kit from yesterday's tractor. I finally got the tractor to lift a bush hog but it drops around one inch per min. Sometimes the hydraulis will stay up once the wheel touches the ground and others it will just fall all they way. I tested the pressures and get around 2100psi before the arms reach the top and the pressure drops to 500. The tractor would not lift the bush hog off the ground the other day but since it snapped cold it has. I was supplied with Traveller Tran & Hyd Fliud for Ford Tractors. It doesn't list a weight on the bucket anywhere. I'm not sure why it still leaks down after replacing the piston seal.
Are there any other tests that I can preform to narrow down the problem?
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t ... [Read Article]
Latest Ad: Looking for a operator platform to fit a 1070 case tractor. Part number is A 62150 old number is A60672. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
