Serial Number Location
tbeals11
New User
I have 1920's Fordson, I believe it is a Model F, not 100% sure though. I was wondering where I would be able to find the serial number on the tractor so I could decode it and find out exactly what I have. Thank you!
Look for it as shown in picture below. This one has a lot of preservative on it (oil and dirt),
but if you blow up the picture, you can see 810834. Engines could have been swapped out at some time
in the past.
Above photo is where its located.
Mine is missing because they did an engine swap. They were supposed to transfer the serial number the new replacement engine . Nobody did that of course .
You might find the year if you look into the differential case casing on inside Im told .but I not going to do that job .
