I have some confusion about fuel lines on my newer 64' Super Major. I need to replace a few fuel lines. I ordered some prefabbed ones from Agriline. Agriline says I need to use Fuel Pipe Washers. Do you take the olives/compression ring off the line or put the fuel line washers on over the olives, in front of the olives? I know this is pretty basic knowledge to be missing but when I googled fuel pipe washers the images seemed to show a different fittings that had a ridge built in ferrule/line nut and the washer was in front of the ridge. The fuel pipe washer that Agriline requires looks like a little piece of fuel or what I was taught as a crush washer minus the copper washers on both sealing surfaces. Any help would be helpful. If I could post a picture I would.
https://agrilineproducts.com/ford-fordson-fuel-pipe-fuel-tap-to-glass-bowl-7529
