Dexta hydraulic filter location
Cav
New User
Anyone have a photo or description or the location of a Fordson dextas hydraulic filter location?
Also having some issues with the rams staying at the desired height and not slowly falling down only have a 5ft slasher attached
To get to the intake filter, the lift has to be removed and the pump taken out of the side. The
filter is a metal strainer and is washable. Does not usually give a problem.
The sinking could be O rings any where in the system or the ram cylinder seals. To check,
raise the lift and pull out the auxiliary services button, if the sinking stops, the ram
cylinder seals are OK.
It could also be wear on the Position Control cam follower pin. Check this if you have to have
the top off.
Cam follower pin
Filter
