Dexta Hydraulics
gebell1301
New User
I'm restoring a 1960 dexta and discovered that the hydraulic ram connecting rod attachment hole is way larger than the attachment pin. The hole in the connecting rod doesn't appear to be worn or distorted. The pin which slides through the ram arm is in good shape. Is this designed this way or is it more likely someone before me changed out the ram connecting rod with an incorrect part? Anyone have a connecting rod they could measure? Thanks, Gary
