Trying to hook up hydraulic hoses on Fordson Major
Duckblaster
New User
Hello, I recently purchased a Fordson major and I am putting a loader on it. I found the hydraulic outlet in front of the seat. However, where do I put the return line? Thanks
This post was edited by Duckblaster on 11/30/2021 at 04:51 pm.
In 1959 Ford changed the oil spec to 20/30W or Universal Tractor oil. You do
not want a hydraulic oil which would not lubricate the crown wheel and
pinion. Best bet would be the same oil as you use in your engine.
(quoted from post at 10:35:14 12/01/21) In 1959 Ford changed the oil spec to 20/30W or Universal Tractor oil. You do
Thank you sir!
