fordson help
vt joe
I have a Fordson Super Major 5000 with the Roadless 4WD and have broken the right front axle...{again} so therefore I need HELP!! The serial number on the Roadless unit is 2044 and i am wondering where I can get a long shaft assembly. I once spoke to John Bownes...is he still around?
If you can,t locate an axle and the break is a clean spiral / rotational break ,, Vee the crack at least 1/4 inch deep .. Then heat axle pieces hot. Use a piece of angle iron to clamp & hold axle pieces , Weld using 7018 rods. Go slowly and tack all along the crack in increments. ( move side to side )to keep axle pieces in alignment , then weld in several time phases. I,ve done this successfully twice with truck axles. Just a thought , in case axle is not available.
