ReMarkabel
New User
Please advise as to a sourse to purchase O-ring for hydraulic
feed tube to lift cover for FSM.
Thank for any info
Hydraulic supplys or even harbor freight has oil rated o ring kits in box . Take it with you and use chart on box to match size
If your orange is missing is missing not sure , match the other o ring on other end of tube.
Just suggestion coming to think of, not familiar with this tube . Good luck
(quoted from post at 18:19:10 08/05/21) Hydraulic supplys or even harbor freight has oil rated o ring kits in box . Take it with you and use chart on box to match size
Thank you Dennis
Ill give that a go. If anyone else out there has experience with
replacing the Hydraulic feed tube o-ring as to its part number and
Perhaps its demensiions; ID OD and CS that would be helpful!
Thanking all in advance!
