Company Logo Shop Now
Fordson Tractors Discussion Forum
FRONT WHEEL WEIGHTS
Marb
02-05-2021 19:17:29
Hi.. Fellow Form Friends. Can anyone tell me the inner diameter of a FMD front wheel hub.. The hub used in conjunction with a 16 inch pressed steel wheel. I am trying to locate front wheel weights and need this dimension to be sure weight will before before I buy.. My tractor is located approx 50 miles from my winter location. I can,t do a hands on measure till April.. There fore I reach oput to the forum in hopes someone can provide this info.. Thanks in Advance.
MarB
02-09-2021 16:19:47
 Re: FRONT WHEEL WEIGHTS in reply to Marb, 02-05-2021 19:17:29
UP-Date.. PICTURES Attached..
I want to thank you guys for your help & advice on the front wheel weights for my FMD. I lucked out today , with a reply to my ad. on Kijiji. The guy sent me a picture & I bought them. Best part was he was only 65 miles from me. Part # on weight casting is C5NN-1N000-A. I weighed them when I got them home. With bolts and nuts in place they weigh 88.8 lbs per pair. I see one post here where a guy installed this part # weight on a Fords 5000. Hopefully they will have a large enough diameter center hole to fit on my Fordson Major.. Its 60 miles from me at my tiny farm so I can,t measure the diameter of the inner hub where weights will be at this time. Can anyone measure or tell me what the inner front hub diameter is on a FMD, FPM or FSM ?? Thanks again
Majorman
02-06-2021 05:07:58
A set of weights from either a Ford 4000 or 5000 will fit, they come in two halves. The original Major weights were a single piece and hard to fit whereas the later weights could be fitted without taking the wheels off.
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Single front for Int M, 706 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
