Company Logo Shop Now
Fordson Tractors Discussion Forum
Fordson F carb
james williams
01-25-2021 14:48:48
Ive got a 234 carb on my tractor with a evaporator.Are these carbs any good and easy to start?Fordson house told me a zenith K5 is a better carb.My question is it worth changing carbs or keeping and working with what I have.The K5 came with the Fordson N.Also will my linkage fit from one carb to the other
thedavid
01-26-2021 14:23:44
 Re: Fordson F carb in reply to james williams, 01-25-2021 14:48:48
The 234 Holley carb was used for the first several years and was later changed to the Holley 280 which was very similar but a somewhat simpler design. The 234 outfit is really a nice looking historical setup and, if complete and properly installed, will provide adequate operation. My experience has been that the 234 makes for rather difficult starting and does not work as well on gasoline as on TVO (kerosene - sort of). I have several 234 setups on a 1918 and a 1919 and they work well until they get really warm at which time they seem to overheat the fuel and begin to run a little rough, regardless of where the shunt valve is directed. For me, it is worth it to have them "correct" but there are other carb setups that would probably be better for operation on gasoline. The later Fordson Model F tractors used several Kingston carbs which seem to run a little smoother. Keep in mind that the manifolds need to be changed to accommodate any different carburetors - they are all different. Some replacement manifolds are available from Rosewood Machine in Rosewood, Ohio. Good luck.
560Dennis
01-26-2021 10:59:58
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=fordson&th=18717
Following this article could be what you need to proceed
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Single front for Int M, 706 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
