Fordson Tractors Discussion Forum |
Fordson Major water pump
Author |
[Modern View] |
redsqwrl
01-11-2021 12:25:53
I have a backhoe on rubber. ( ottawa loader )
supposed to be a 1954 fordson major.
both serial number spots are blank. ( I scrubbed and sprayed )
I need a water pump and purchased a 1106-6202 ( Atlantic number)
The improved coolant slot winds up on the out side of the engine just ever so slightly.
can anyone point me towards what to ask for... most retaliers are telling me that the new pump fits either.
Im about to weld the hole and machine. thoughts?
redsqwrl
01-12-2021 14:58:56
Re: Fordson Major water pump in reply to redsqwrl, 01-11-2021 12:25:53
thanks for the encouragement. I may weld up the housing with a nickel rod and relocate that hole. have you heard of any reasons to not do that?
redsqwrl
01-12-2021 05:17:08
Yes I have scoured that area, I see the pad or flat area but there is nothing stamped there. Thank you for My IT manual says the split is at serial number 1425097.
I was told it was a 54' same person told me the numbers were ground off when it left O'hare airport back in the day.
I may add onto the block or weld/ Braze up the passage. it is just barely not on a sealing surface.
Maybe I can disassemble the new pump to save the old
Majorman
01-12-2021 06:42:21
Re: Fordson Major water pump in reply to redsqwrl, 01-12-2021 05:17:08
There is no pad or flat area on the flange, it is just stamped into the casting behind the starter. Also they will not have ground all the casting codes off which will give you and accurate date.
Majorman
01-11-2021 14:26:56
Your serial number will be on the flange where the block joins the gearbox, behind the starter. The water pumps are not the same, you need one for a 1952 to 1957 model. It might be easier to put a new bearing and seal in your old one.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Complete set of 12 inch John Deere BO Lindeman pads. Very nice shape
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
